Mask feathering creates hard line?
Omur Sonmez
on Dec 7, 2015 at 10:58:50 pm
Hello,
I have a shot where I have to merge two backgrounds and try to do it seamlessly. It works to an extent when I mask one part over the other, and just feather it out because they're a bit alike. But no matter how much I feather, there is always this obvious hard line in the feather that moves unnaturally.
Is there a way how I can just create a soft transition that isn't too noticeable?
Thanks in advance.
Dave LaRonde
Re: Mask feathering creates hard line?
on Dec 7, 2015 at 11:30:25 pm
Sure-the feathering in the mask is probably picking up the edge of the image. You simply move the mask a bit.
Dave LaRonde
Promotion Producer
Omur Sonmez
on Dec 8, 2015 at 9:03:58 am
I try to move the feathering, but the line moves along with the mask. There also isn't an edge that close. It's like a noticeable line in the middle of a soft feathering.
Walter Soyka
on Dec 8, 2015 at 3:00:48 pm
[Omur Sonmez] "I try to move the feathering, but the line moves along with the mask. There also isn't an edge that close. It's like a noticeable line in the middle of a soft feathering."
Can you post a couple screenshots showing your UI and the problem you're having? It would be great to see a sequence of screenshots showing each layer in the composite as well as the mask itself.
Walter Soyka
Omur Sonmez
on Dec 9, 2015 at 8:30:05 pm
I moved the mask to make it more noticeable. But it's really only noticeable when it's in animation. I just crank up the feathering. But there's always a hard line present. It's close to the center in the first picture.
Dave LaRonde
on Dec 9, 2015 at 10:12:26 pm
Are you referring to the red mask outlines? They won't render.
If you're talking about something else, do you see it if the comp size is set to 100% and not 50%?
Dave LaRonde
Promotion Producer
Omur Sonmez
on Dec 10, 2015 at 10:39:27 am
It's not the red line,
I'll try to zoom in a lot more or a way that it's more noticeable.
