Wiggle points in a path
Andreas Ruso
on Dec 6, 2015 at 4:48:51 pm
Hi there! Is there a script or a way to do a wiggle expression on some points of a path in a shape?
Lets say there is 30 points, and i want 5 of those to wiggle.
Kalle Kannisto
Re: Wiggle points in a path
on Dec 6, 2015 at 5:53:15 pm
Nope.
I usually go with a puppet-pin solution.
If it is a non-filled shape with straight lines, you can use nulls and a bunch of beam effects to draw the lines.
Andreas Ruso
on Dec 6, 2015 at 7:46:15 pm
Thanks! I actually tried with puppet tool linked to nulls, but as 3D layer and camera the shape layer got broken. Pre-comp solved this issue. Didnt think of that. Thanks for your answer Kalle.
Walter Soyka
on Dec 7, 2015 at 6:28:14 pm
[Andreas Ruso] "Hi there! Is there a script or a way to do a wiggle expression on some points of a path in a shape? Lets say there is 30 points, and i want 5 of those to wiggle."
I know you've already solved the issue, but there is a third-party solution:
http://aescripts.com/bao-mask-avenger/
Walter Soyka
