Rotation of composition with a repeater inside (déformation)
max arch
on Dec 5, 2015 at 4:40:46 pm
Here the problem,
when i rotate there a deformation that happen. I want that it stay as square.
First, I have try to rotate only the reapeater.
Next, I have create a new composition(square). Thinking no deformation will happen, since it not the repeater I rotate but my composition inside a other composition.
From what i know it suppose to work but.... I don't know where the problem happen and how to correct it.
hope i am clear.
Kalle Kannisto
Re: Rotation of composition with a repeater inside (déformation)
on Dec 6, 2015 at 7:45:28 am
Either the containing composition is not scaled proportionally, in which case the easiest solution is to scale it proportionally, OR you have a non-square pixel aspect ratio, and need to turn on pixel aspect ratio preview (click the icon with rectangle and horizontal double arrow below the viewer).
max arch
on Dec 6, 2015 at 2:50:09 pm
thanks
i will check that
