cc 2015: still camera gizmo (triangle) while positioning other layers around
ling talfi
on Dec 3, 2015 at 8:48:45 am
Hi, I'm trying to follow this basic tutorial:
In the video, the author creates three circle shapes and a camera.
Then he switches to "2 Views" and using the top view, he can position the three circles while having the camera gizmo (I don't know the actual name, but I mean the triangle that shows where the camera is looking at) visible.
As far as I'm concerned, as soon as I click on a circle layer, the camera gizmo disappear, which is annoying, because I have to guess where the triangle is.
Is there anything I can do about it with cc 2015 ?
Cassius Marques
Re: cc 2015: still camera gizmo (triangle) while positioning other layers around
on Dec 3, 2015 at 11:51:08 am
you can go into View -> View Options (shortcut ctrl + alt + U) and set camera wireframes to allways on.
Cassius Marques
http://www.zapfilmes.com
ling talfi
on Dec 3, 2015 at 11:55:59 am
Thanks a lot.
Sounds obvious when you know where it is.
