AE 'blurring' when I move an object
sean brannigan
on Dec 2, 2015 at 1:39:33 am
I'm having a problem with AE.
When I import an image it is nice and sharp.
The problem is when I move the image, I'm trying to make an 8-bit animation, I get a blurring or more accurately it appears as it is being anti-aliased.
I have no idea why it is doing this and cannot figure out how to stop it.
I've uploaded an image so you can see what I mean
<a href="https://images.creativecow.net/304793/box.jpg"><img src="https://i1.creativecow.net/u/304793/box.jpg" border="0" /></a>
It might not look like much but on a more detailed object the effect is really apparent.
I'm using AE CS6 version 11.
Thank you
Kalle Kannisto
Re: AE 'blurring' when I move an object
on Dec 2, 2015 at 12:29:16 pm
Answer and solution can be found here:
http://chrissilich.com/blog/after-effects-expression-snapping-objects-to-wh...
sean brannigan
on Dec 2, 2015 at 2:14:37 pm
Brilliant.
That's it.
I would never have even known what words to use to do a google search.
It works like a charm so thank you so much, I extremely happy with the result.
sean brannigan
on Dec 11, 2015 at 2:43:30 pm
That did work on the first item I used it on but now for all the rest it offshoots them when I enter the expression so it leaves them with a constant AA effect.
Cannot figure out how to stop it or why it worked the first time
sean brannigan
on Jan 24, 2016 at 6:30:35 pm
What I ended up doing was setting the layers causing problems to draft and then when I rendered out the video I chenged the settings from Best to Current and that worked perfectly everytime
