3d Projection Mapping Issues
Michael Dominic
on Nov 30, 2015 at 2:47:14 pm
I have two questions.
1. When I make a 3D projected image, the image gets softer and loses detail. It there a way to avoid this?
2. Is there a way to feather the edges of the screens so when/if they move apart the shift isn't so obvious?
Thanks.
Dave LaRonde
Re: 3d Projection Mapping Issues
on Nov 30, 2015 at 3:45:53 pm
How much are you enlarging the original image by projecting it, do you think? You can't make it much bigger without seeing softness.
Dave LaRonde
Promotion Producer
Michael Dominic
on Nov 30, 2015 at 4:06:37 pm
I don't think it's getting scaled up. Is it?
Dave LaRonde
on Nov 30, 2015 at 5:16:45 pm
It could be; you may be relying on the projection for some foreground objects to which a camera is very close. If the image the AE camera sees goes beyond 100% of the source image's scale, it'll get soft.
Dave LaRonde
Promotion Producer
