Workflow Confusion w/ Detail Preserving Upscale
Matt Frame
on Nov 30, 2015 at 12:41:14 pm
I have footage shot on my Sony ax-100 in 'High Speed Record' mode, which is 120fps.
Unfortunately, the resolution for that mode is only 1280 X 720.
I'd like to incorporate that footage into an ultra HD (3820 x 2160) project so I'll be needing to upscale using 'Detail Preserving Upscale' in AE CC-2014.
But I also am needing to have the exported footage slowed to 23.976.
So, my question is about workflow.
Just wondering if...
the best way of doing this to interpret the footage at 24fps, create new composition w/ 3820 x 2160 resolution, add the 'Detail Preserving Upscale' effect to that, then export (using Media Encoder) to high bitrate Ultra HD (3820 x 2160) settings?
Or...
is there a better way that can yield better looking results?
Thanks much!
Dave LaRonde
Re: Workflow Confusion w/ Detail Preserving Upscale
on Nov 30, 2015 at 3:31:04 pm
The workflow is just about right, but with one significant change. If you have to deliver 23.976, do EVERYTHING in 23.976 -- interpret footage, comps, the whole shootin' match.
Also know that although that even though Detail Preserving Upscale works pretty well, it can't work miracles. You're asking for a miracle. You'll see a visible difference in the upscaled footage.
You may also want to consider transcoding the Sony footage to a lossless codec to aid in rendering speed BEFORE you import it into AE.
Dave LaRonde
Promotion Producer
Matt Frame
on Dec 1, 2015 at 7:04:11 am
Thanks very much Dave!
