After effects problem!
Mike Thompson
on Nov 28, 2015 at 4:24:52 am
I'm trying to create an animation in cs6 using the following plugin: http://aescripts.com/construction/#
The instructions say to create the animation with 'fast draft" selected. When I try to export the composition, or click off fast draft, the images get all jumbled up and are not in their proper space.
I'm guessing that I must do something before rendering the composition in order to maintain the integrity of the animation. Any help would be appreciated.
Tudor "Ted" Jelescu
Re: After effects problem!
on Nov 30, 2015 at 9:07:27 am
From what I know it seems that the plugin only works in fast draft. So if you want to layer other elements to it, you need to render the buildings/boxes in fast draft mode with an alpha and then composite the rest after and render in full resolution mode.
Tudor "Ted" Jelescu
Senior VFX Artist
