Trying to export and Output Preview (and final result) totally warped and distorted
Aaron Jones
on Nov 27, 2015 at 1:17:58 pm
Help! I'm quite new to Ae and haven't done a lot of exporting of anything over about 10 seconds so far. I've animated a 1.30min composition, but when I try to put it through the Media Encoder CC, the result is horribly warped, although the sound is fine.
Here's it looking weird in the Output Preview - yes the final result looks like that too, unfortunately.
https://infinit.io/_/kYKDLYf
Here's what it should look like!
https://infinit.io/_/3afkmeN
Does anybody have an idea of what I should do differently - have you seen this before?
Dave LaRonde
Re: Trying to export and Output Preview (and final result) totally warped and distorted
on Nov 27, 2015 at 7:21:17 pm
Sorry, the links don't work.
Does "warped" mean "squeezed horizontally"?
If so, work in square-pixel comps. What's the VERTICAL dimensions of the problem comps? If we know that, we can make a recommendation.
Dave LaRonde
Promotion Producer
