Effect controls window not showing my effects
Keltie Larter
on Nov 26, 2015 at 8:19:00 pm
Hi, I'm using some text animation presets on text in After Effects CC. The effect works and I have the effect controls panel open but when I highlight the text layer there aren't any effects showing in the effect controls panel. I'm working on a mac. Please help!
Kalle Kannisto
Re: Effect controls window not showing my effects
on Nov 26, 2015 at 10:13:06 pm
If it is one of the built-in animation options from within the Text layer itself (From under the "Add" menu of the Text layer) it won't show up in the Effects panel. Only actual Effects do. Twirl open the text options on the layer itself.
Keltie Larter
on Nov 27, 2015 at 2:31:21 am
Oh ok! Thanks!
Thomas Brecheisen
on Nov 27, 2015 at 6:55:13 am
For anyone with a similar situation, but not the Built-in effects, make sure your effects tab isn't "locked" to a layer that has no effects added. There is a little lock at the top of the effects tab, that should look unlocked.
