After Effects, Beam and Square caps?!
Simon Tibbs
on Nov 25, 2015 at 4:59:50 pm
Hey CC Community!
First off, thank you for all the help over the years. You have solved many head aches!
My problem: AE's Beam and it's round cap. Is there any way to make a butt cap (square, not round)?
I've tried all sorts of tricks; using Mattes to square the end, for example- unfortunately this doesn't work with my rig.
A work around would be to use a shape layer line, but I can't find a way of attaching the end of the points to a null.
Any thoughts would be hugely appreciated!
Simon
Dave LaRonde
Re: After Effects, Beam and Square caps?!
on Nov 25, 2015 at 6:15:09 pm
I can't think of any good way to do it, especially if you use those inner color/outer color & feather settings.
You could TRY to use a solid as a track matte, which uses the same starting and ending points as the beam and moves at the same speed at the beam animates, but even with a feathered edge, it's still going to look goofy.
Dave LaRonde
Promotion Producer
Walter Soyka
on Nov 25, 2015 at 7:18:37 pm
1) Use a shape layer or solid instead of beam. Use trigonometry and expressions to draw the line from one point to another by anchoring at the first point and rotating/scaling it out to the second point.
2) Check out BAO Mask Avenger [link] to get control of the individual points of a mask/shape.
Walter Soyka
Simon Tibbs
on Nov 26, 2015 at 1:31:36 am
Thank you both for your response, it's much appreciated.
Mask avenger looks very useful. Before I purchase, would I be able to attach shape path points to nulls via the plug in?
Thanks again,
Simon
Walter Soyka
on Nov 26, 2015 at 2:07:08 pm
[Simon Tibbs] "Mask avenger looks very useful. Before I purchase, would I be able to attach shape path points to nulls via the plug in?"
It also comes with BAO Shape Avenger. Try the demo to make sure it's what you want.
Walter Soyka
