After Effects Plug-in Recognition
Mark Chatman
on Nov 25, 2015 at 4:07:06 pm
Well there's a plugin that I've been looking for yasterday,but I didn't find it :)
Now I've a better way of recognizing it .
When the clap comes and those lines appear,which effect/plugin is that?
I know which's the plugin that distorts it but which's the plugin that makes those glitchy lines :)
Mark.
Daniel Waldron
Re: After Effects Plug-in Recognition
on Nov 25, 2015 at 8:16:02 pm
Do you mean the horizontal glitch effect, or the line looping around the text?
If you're going for the glitch effect, there are several out there. Just look up Bad TV effect for After Effects. My favorite is Twitch.
If you want to make the glowing line that loops around, you can use Trapcode Particular.
Mark Chatman
on Nov 25, 2015 at 8:39:39 pm
The horizontal ones,because the one that's looping around the text is a normal helix spline made in cinema 4d.
The horizontal one is which?
Twitch?
Which settings should I use to achieve that?
