Text transitions to birds flying
Meliha Cicak
on Nov 24, 2015 at 7:05:31 am
I need to make as the title suggests some text to transition into flying birds. Could someone give some useful advice.
I used shatter in combination with the particle system but it is too much like explosion. I guess I will probably have to do it by hand but if there is some shortcut I would appreciate some direction...Thank you.
John Cuevas
Re: Text transitions to birds flying
on Nov 24, 2015 at 4:06:36 pm
I would look to Trapcode Form
Maybe one of these Tutorials, could give you a starting point.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Meliha Cicak
on Nov 26, 2015 at 9:06:27 am
Thank you John for quick reply. I will sure look into the tutorials you sent me link to. Thanks.
As for the transition I did it by hand for each letter - just some basic shape transitions (I was in a hurry so no time for experimentation :)). Thanks again.
Cheers.
