Rendering different versions
Kasper Nyman
on Nov 23, 2015 at 10:36:59 pm
Hi, is there a plugin, script, workflow something that makes it easier to make quick versions of the same video?
Example, I have create this video for a sneaker company, and have to make 500 different versions where the endslate have different names of athletes. is there some way I can loading a txt file, and it will change the text-layer to a name, render it out and name it after the input name?
Best,
kasper
Nyman
Dave LaRonde
Re: Rendering different versions
on Nov 23, 2015 at 11:13:53 pm
Do it in a video editing application, not AE. Sincde this is not something you can automate, it'll make life a lot easier.
In broadcasting, we call these things "tags". Think about a promo for a show that airs in two weeks -- you need to tell viewers to watch on the specific date and time, then the day of the week & time once the air date is less than a week out, then a "tomorrow" version, and then a "tonight" version.
You're doing tags, so use what we use -- a video editing application. You've just got more tags to do, that's all.
And if you have to re-design your AE animation to do it in an NLE, by all means do it.
Dave LaRonde
Promotion Producer
Walter Soyka
on Nov 24, 2015 at 12:48:03 am
Check this out:
http://aescripts.com/compsfromspreadsheet/
Walter Soyka
