UpperField Prerenders
Lenz Eternel
on Nov 23, 2015 at 10:00:06 pm
Hello.
I need help with understanding how to prerender when working fith upper field
I am working with TV channel and i need to send them final renders in H.264, 1920x1080, Upper field first. The problem is - it is very slow to render and when the clients want to change something, we need to rerender everything. The solution is to use prerenders. But I dont understand how to use prerender, in what field should i prerender, what output module should i use? or how should i interpret the prerender footage?
Dave LaRonde
Re: UpperField Prerenders
on Nov 23, 2015 at 10:33:26 pm
That's an odd specification. H.264 doesn't HAVE fields! It's progressive.
Dave LaRonde
Promotion Producer
Lenz Eternel
on Nov 23, 2015 at 11:17:26 pm
Can you explain? There is an option in after effects to render h.264 in upper field or lower field first, so i dont understand what do you mean
Dave LaRonde
on Nov 23, 2015 at 11:23:00 pm
AE may let you render in fields, but the final H.264 file won't have fields. H.264 does not have fields, It's progressive-only.
I would double-check those delivery specs. Someone has something fouled up. Besides, it's not a problem to play progressive-frame video on TV. Have you ever watched a movie on TV? They're shot in progressive.
Dave LaRonde
Promotion Producer
Lenz Eternel
on Nov 24, 2015 at 11:42:25 am
Yeah, i know its weird specification, but this is what they told us to do. Until november, we were rendering in 720 x 576 with 1.46 pixel ratio, lower field first avi dv pal. But in november they went to hd, but still asked to render in upper field.
And i still dont understand, i can clearly see an interlacing in our renders in h.264, which means there are fields, am i wrong?
Walter Soyka
on Nov 24, 2015 at 12:01:19 pm
H.264 does support interlaced-scan encoding.
You will want to change your render settings for your pre-render so that "Field render" is on. Then you could use a lossless output module, or build a visually lossless output module with ProRes or CineForm.
What version of Ae are you using? What are your computer specs? Do the comps you need to pre-render contain alpha?
Walter Soyka
Lenz Eternel
on Nov 24, 2015 at 2:00:58 pm
I am using cs6. I have i7 960, gtx 660, 24gb ddr3, windows 7 64. I dont need alpha in prerenders.
