Expression for Mirroring a value but setting different max and min parameters
Brian Lee
on Nov 23, 2015 at 6:50:25 pm
I'm trying to mirror the Blur Radius of a camera lens blur effect to the opacity of the text layer of which it is applied. Pickwhipping the blur to the opacity is easy enough however when the opacity=0% I want the blur radius to be "11" and when the opacity=100% i want the blur effect to be "2". So for instance if I animate the opacity property to go from 0%-100% i want the blur radius to decrease from 11 to 2 at the same rate.
Is there as an expression that I can apply that will allow me to do this?
Kalle Kannisto
Re: Expression for Mirroring a value but setting different max and min parameters
on Nov 24, 2015 at 7:19:58 am
For lens Blur Radius:
linear(transform.opacity, 0,100,11,2)
this takes the opacity value and linearly interpolates it from 0-to-100 range to 11-to-2 range.
Brian Lee
on Nov 24, 2015 at 4:53:50 pm
Thank you so much! That worked perfectly and will now be using this very powerful function so much more in my work.
Brian
