Display resolution guide for after effects
Mit Panchani
on Nov 23, 2015 at 4:54:27 pm
I am on 1370×768 resolution on 19'' monitor.
Problem is - i have very little room to accommodate time line and video preview panel om screen.
I have to resize in between to have better look on either of them.
I am wishing to upgrade the display.
What is better that can provide enough room?
24'' 1080p?
24'' 1440p?
1440 will be looking too small. So will 1080p display, if any one of you currently using provide sufficient room without resizing time line and other panels?
Dave LaRonde
Re: Display resolution guide for after effects
on Nov 23, 2015 at 5:52:07 pm
Just go out and get any decent computer monitor. You should be good. Now, if you're talking about an additional VIDEO monitor, that's a different story and you have to tell us that.
Dave LaRonde
Promotion Producer
Mit Panchani
on Nov 23, 2015 at 7:21:37 pm
Yes, as far as old monitor works will use it as extended desktop. But if you assure that 1080p is sufficient and there's no need for 1440p, then i shall get it.
Dave LaRonde
on Nov 23, 2015 at 9:36:18 pm
My monitor at home is 1920x1080 and AE runs fine on it. But it wouldn't hurt to have a little more vertical resolution with 1440, either.
Dave LaRonde
Promotion Producer
Walter Soyka
on Nov 25, 2015 at 10:55:54 am
How about a 1920x1200 panel instead of a 1920x1080?
Walter Soyka
Mit Panchani
on Nov 25, 2015 at 10:57:40 am
Not bad, will add 120 pixels more vertically
Walter Soyka
on Nov 25, 2015 at 11:12:01 am
[Mit Panchani] "Not bad, will add 120 pixels more vertically"
That's 7 more layers in the timeline panel!
Walter Soyka
Mit Panchani
on Nov 25, 2015 at 11:25:14 am
You were the first one to tell what i was wanting to know from long time.
i m on 1378×768* resolution and can accommodate 8 layers after resizing preview panel.
If at all u can approximately say.. How many layers do we have as in:
1080p
1200p
1440p
Walter Soyka
on Nov 25, 2015 at 12:06:19 pm
[Mit Panchani] "i m on 1378×768* resolution and can accommodate 8 layers after resizing preview panel. If at all u can approximately say.. How many layers do we have as in: 1080p / 1200p / 1440p"
A layer takes 17 pixels (16 for the layer, 1 for the separator line).
With your given sizing, 8 layers * 17 px/layer = 136 px.
768px - 136px = 632px for the rest of the UI.
1080px - 632px = 448px / 17px/layer = 26 layers
1200px - 632px = 568px / 17px/layer = 33 layers
1440px - 632px = 808px / 17px/layer = 47 layers
Walter Soyka
Mit Panchani
on Nov 25, 2015 at 12:11:55 pm
30 layers sounds amazing. Thanks for the calculates.
