how can achieve this smoothness?
Francisco Manzanares
on Nov 21, 2015 at 10:16:43 pm
hi guys, im trying to do this transition:
but i can't achieve the smoothness of those transitions.
i've using twixtor for a while.
any tutorials?
thanks!
Dave LaRonde
Re: how can achieve this smoothness?
on Nov 22, 2015 at 4:52:47 pm
There are two basic paths to smoothness: slow the animation down or increase the frame rate. I can't see the link so I can't tell which was used... but I bet it was done at a higher frame than you sre using.
Dave LaRonde
Promotion Producer
Daniel Waldron
on Nov 23, 2015 at 3:08:48 pm
Most video games now can be played a 60fps, so you should record your screen at that frame rate, put it in a 24fps or 30fps timeline, and do some time-remapping to achieve the effect.
