Shape Layer unaffected by distance from light source, is this a bug or is there solution?
Jeff Cottle
on Nov 21, 2015 at 7:18:06 pm
Hello AEForum Members,
i'm not sure if this is a bug but when i use a Shape Layer with a "Smooth" light source then the Shape Layers' light reflection does not darken with distance from light, or brighten when closer. The Shape Layer is also unaffected by light "falloff" radius or distance.
Any solution or suggestions greatly appreciated,
thanks,
Jeff
Kalle Kannisto
Re: Shape Layer unaffected by distance from light source, is this a bug or is there solution?
on Nov 22, 2015 at 12:29:11 pm
No such problem here (CC14). Which version of AE are you running? What are you light's falloff settings?
Jeff Cottle
on Nov 22, 2015 at 3:54:07 pm
Thank you Kalle,
for the quick reply as well, mine would have been as fast had i known.
- i'm using AE v12.1.0.168,
- Falloff settings: Smooth, Radius=500, Falloff Dis.=10000
..and the Shape Layer is "Auto Scaled" to z=5000 pixels, but at any distances its surface light reflection remains unchanged,.
Talk soon,
Jeff
Dave LaRonde
on Nov 22, 2015 at 4:56:48 pm
Do you have the layer set to "Accepts Lights" in the Physical Properties?
Dave LaRonde
Promotion Producer
Jeff Cottle
on Nov 22, 2015 at 5:06:34 pm
Hi Dave,
yes, Mat.Opt's."Accept Lights" is enabled,.
Jeff Cottle
on Nov 22, 2015 at 7:24:22 pm
Thanks Kalle,
looks like CC14 is answer sofar, will give it a try,
J
Kalle Kannisto
on Nov 23, 2015 at 8:50:35 am
Sounds good. CC14 seems to be the most workable version currently.
Bug hunting is a process of elimination, so it is good to check with another version of the program, and on another computer, to see if it is a software version or hardware issue. Or ask someone else if it works on their system :)
