Problem with Puppet on shape layer
Ron Boscacci
on Nov 20, 2015 at 11:36:02 pm
When I create a shape, then place the puppet effect on it, then transform the the shape(position, rotation etc) the the puppet points don't move with the shape, they hold there position. Can puppet be made to move with the shape. Seems like I've seen this done. What am I doing wrong.
Dave LaRonde
Re: Problem with Puppet on shape layer
on Nov 21, 2015 at 1:42:45 am
You can ONLY have the puppet tool on a layer. No transforms, no effect, etc. If you want it to rotate, you need to precomp the layer after the puppet work is done.
Dave LaRonde
Promotion Producer
Ron Boscacci
on Nov 21, 2015 at 9:02:29 pm
Thanks, it makes sense now.
