Element Reaches full stop - Graph Editor
Jesse Wekerle
on Nov 11, 2015 at 10:21:54 pm
Doing a position transform in 3D space but the element reaches a full stop, how can I edit this graph so the element never fully stops?
Dave LaRonde
Re: Element Reaches full stop - Graph Editor
on Nov 11, 2015 at 11:11:34 pm
Change the keyframe at 15 frames to a Hold keyframe.
Dave LaRonde
Promotion Producer
Jesse Wekerle
on Nov 12, 2015 at 3:11:02 pm
Thanks Dave, but no dice. The hold keyframe still shoots the curve down to zero, and when I attempt to pull the flat of the curve up, the keyframe reverts back to a continuous bezier which refuses to pull entirely up from zero. Any other suggestions?
Michael Szalapski
on Nov 12, 2015 at 8:35:25 pm
I've found this kind of animation is easier to do if you separate dimensions and then use the value graph instead of the speed graph.
- The Great Szalam
