textual landscape
Vincent Lablee
textual landscape
on Nov 9, 2015 at 10:25:52 am
hei,
i'm looking for advice to construct a form of "textscape" or textual landscape in adobe after effects cc, on one channel/screen. i'd like it to be "moving" or in "motion" in a "geological" form/mass of landscape. ill add references below.
does anybody have any good tutorials to create a similar structure of text?
(see first 7 seconds and 0:29 - 0:33)
(from 12 seconds in)
thanks
John Cuevas
Re: textual landscape
on Nov 9, 2015 at 2:27:16 pm
I think there are a few methods that could get you those results. For plugins, Trapcode Form, and Mettle Shapeshifter both could produce those results.
If you want to stay within AE, I you would want to precomp some type white/black map and then use the distort - displacement map effect, maybe in combination with some other of the distort effects(bezier warp, mesh warp, bulge).
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Chris Bobotis
on Nov 9, 2015 at 2:53:48 pm
FreeForm Pro would be perfect for this.
Very easy to pull this effect off and very fast to render. See: http://www.mettle.com/product/freeform-pro/
Come to think of it, I will add this to my list of tutorials for FreeForm pro. Thanks, great idea for a use of FreeForm Pro :-)
Cheers,
Chris
mettle.com
John Cuevas
on Nov 9, 2015 at 5:11:15 pm
Yeah, that's what I meant, Freeform Pro, not shapeshifter.
ThinkCK
Chris Bobotis
on Nov 9, 2015 at 6:26:58 pm
Here is a quick set-up of a Textual Landscape using FreeForm Pro in After Effects (see attached png):
9437_textterrianfreeformpro.png.zip
Cheers,
Chris
mettle.com
Chris Bobotis
on Nov 9, 2015 at 6:29:36 pm
And here it is again (inline):
Cheers,
Chris
mettle.com
Chris Bobotis
on Nov 9, 2015 at 7:21:25 pm
And here is the project file (see attached)... as I mentioned earlier... quick & dirty... needs love but a good start nonetheless :-)
9438_ffprotextuallandscape.aep.zip
Cheers,
Chris
mettle.com
