AE displays font differently than intended?
Jessie Zus
on Nov 9, 2015 at 1:00:42 am
I downloaded the font, "Castro Script" and intended to use in After Effects. However, it looks much different in After Effects than it looks in Illustrator. I've attached a photo of what I'm seeing in AE. The top text is an illustrator file imported into AE, the bottom text is a text layer written in AE.
9432_screenshot20151108at7.53.38pm.png.zip
Why is this happening?
Iwan Smith
Re: AE displays font differently than intended?
on Nov 9, 2015 at 4:53:40 am
Hi Jessie
It is because you don't type with the Castro Script font
Try to delete the text layer and retype your text, not copy-paste
Your text should look like the first line
http://iwansfactory.com
Motion graphics portfolio
Jessie Zus
on Nov 10, 2015 at 6:28:48 pm
I was typing with that font.
What I realized later is that I had the option "All Caps" on, which was distorting my font.
Thank you for your response though!
Iwan Smith
on Nov 10, 2015 at 8:04:04 pm
I am glad it solved easier then expected, Jessie :)
