What [ Windows ] computer works best with Adobe AE?
Tanya Lebroy
on Nov 6, 2015 at 5:28:30 pm
Hello. I wanted to know what works best for Adobe AE because I am on Windows 7 Home Premium 64 bit toshiba sattellite L775d 4098MB RAM, but I don't think it's working well for it because every time I render my movie, it renders messed up (25% of the audio, then stops, then turns black).
Also does anyone know if I save my project to my external hard drive, will it work? I've tried many times, and I'm about to just give up.
Iwan Smith
Re: What [ Windows ] computer works best with Adobe AE?
on Nov 6, 2015 at 10:03:41 pm
Hi Tanya,
I think you are trying to export the RAM preview.
You need to select the composition you would like to render, then hit 'CTRL+M' on your keyboard, this will bring you to the 'Render queue' where you can set up file name and format, then you need to click the 'Render' button.
I hope it helps, contact me at http://iwansfactory.com/ if you need more help, please!
Motion graphics portfolio
Tanya Lebroy
on Nov 7, 2015 at 3:12:05 am
It's at the point where it keeps crashing. :|
Iwan Smith
on Nov 7, 2015 at 9:07:08 am
Don't you get any error message?
Can you upload the project and send me a download link? Maybe through wetransfer.com
If you send me the link through my site http://iwansfactory.com/ I get a notification
Jon Doughtie
on Nov 9, 2015 at 2:18:06 pm
You do not mention what version of After Effects you are running, but. . .
4GB of system RAM is very low to run After Effects.
I am guessing you are creating RAM previews and rendering media onto the same system drive and not outboard storage. If so, the onboard drive is (I believe) a 5400rpm drive on that laptop. Again, VERY slow for After Effects.
From what I looked up, You are also running AMD chipsets, which I believe After Effects is not in love with.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
