Scaling the value of keyframes?
Gabrielle Ray
on Nov 4, 2015 at 11:47:33 pm
Hi All,
I'm having to rebuild a puppet with a higher resolution than the original one, but unfortunately have already animated with the old, low resolution puppet. I am using Duik to rig the puppet. My keyframes are on controllers that I can copy and paste the values with, but since my new puppet will be higher resolution, there are more pixels to cover and the actions are not coming across clearly. Is there an easy way to scale the value of my keyframes? For example, frame one, the position value is 2,5 - how can I automatically scale so that new values are 4,10 and so on? In Maya all you have to do is select all your keyframes and use a scale tool to scale vertically in the graph editor. I'm hoping there is an easy way to do the same in After Effects.
Kevin Camp
Re: Scaling the value of keyframes?
on Nov 5, 2015 at 12:47:03 am
you could try an expression like:
value * 2
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Gabrielle Ray
on Nov 5, 2015 at 12:53:36 am
That solves my problem perfectly! Thank you!
