How to render 29.97i comps?
Ace Billet
on Nov 2, 2015 at 3:46:31 am
Working on a graphic packaging for a show.
The elements are vector graphics and some QT renders from Cinema4d.
I'm asked to deliver 1920X1080 QT files at 29.97i.
What's the best MO?
1) Work in 29.97 comps in AE, render out Upper Field First
2) Work in 59.94 comps in AE, render out 29.97 - Upper Field First
[according to this relic from 2004: http://www.adobe.com/support/techdocs/317681.html ,
in the last paragraph]
3) Work in 29.97, render Progressive, interlace when importing to Avid.
Also, do I need to render out my 3D comps interlaced?
thanks!
David Baud
Re: How to render 29.97i comps?
on Nov 2, 2015 at 4:37:30 am
I would say your option #1, unless you have fast action and then option #2 might make more sense. Do all your compositing work in progressive and then export interlaced.
David Baud
Post & VFX
KOSMOS PRODUCTIONS
Denver - Paris
http://www.kosmos-productions.com
Dave LaRonde
on Nov 2, 2015 at 3:34:47 pm
I agree that Option 1 is best. I'm curious about the frame rate of the C4D footage and if it's progressive/interlaced.
Dave LaRonde
Promotion Producer
Ace Billet
on Nov 2, 2015 at 4:04:09 pm
Yep, Dave, you're right.
Rendered some animation in both 29.97 and 59.94.
The latter looks more "video".
Both clips were rendered Upper First and when checked on a TV played OK -
no combing artifacts.
C4D was rendered @ 29.97 progressive, and looked fine in the AE comp.
Since the 3D stuff is pretty short I'm rendering QT - will an image sequence make any difference?
Ace Billet
on Nov 2, 2015 at 4:46:20 pm
Here are some broadcaster specs, to confuse me more:
I. HIGH DEFINITION VIDEO (1080i/59.94)
(1) The video information must be recorded on 1125 total lines, 59.94 fields or 29.97 frames per second. Active video must occupy 1920 samples horizontally and 1080 lines vertically with a 1.78 (16:9) aspect ratio.
Dave LaRonde
on Nov 2, 2015 at 5:52:09 pm
I'd imagine there are more to those delivery specs besides what you posted. Media container, codec and bit rate come to mind right away.
Dave LaRonde
Promotion Producer
Ace Billet
on Nov 2, 2015 at 6:16:53 pm
Well, all my stuff goes into Avid, and the editors are dealing with final delivery.
I'll deliver DNxHD or Animation.
The show is shot / cut at 59.94 1080i, so my comps will comply.
Dave LaRonde
on Nov 2, 2015 at 10:30:27 pm
Great, you're set. It was that "1125 lines" requirement that threw me. Those 45 extra lines are for broadcasters. Since editors get your stuff next, they're irrelevant to you.
Dave LaRonde
Promotion Producer
