Wiggle expression . 1 time in 1second?
Vugar Ashrafov
on Oct 31, 2015 at 6:31:24 pm
Maybe it is very simple and easy subject , but i dont understand this "wiggle" expression all the time. We all know(or only me :D ) that for example
wiggle (1,15) , here "1" shows that wiggle should happen 1 time in one second.but when i try this, it happens 6 times in one second. any idea?
Kalle Kannisto
Re: Wiggle expression . 1 time in 1second?
on Nov 1, 2015 at 5:23:25 pm
What property are you applying it to when this happens?
Vugar Ashrafov
on Nov 1, 2015 at 8:39:56 pm
i try on rotation . i write wiggle(1,random(-2,2))
Kalle Kannisto
on Nov 3, 2015 at 2:05:44 pm
It's not the first part of the expression that gives you the trouble, you are giving the wiggle a new random number for every frame with the second part of the expression.
The correct wiggle expression in this case would be
wiggle (1,2)
With the value of 2 the wiggle expression itself will vary the results between -2 and 2 in relation to current value.
