Best Codec For Exporting 16 or 32-bpc With An Alpha Channel on Windows
Ryan Paterson
on Oct 28, 2015 at 9:30:07 pm
Hello, recently switched from a Mac to a PC and without the use of ProRes now I'm trying to find a suitable replacement for rendering high-quality footage. Can someone recommend a codec that fits the specs in the title please? It seems AVI & Animation only support 8bpc, and I'm just plain unfamiliar with anything else really. Any resources regarding this topic are also welcome, wouldn't mind doing a little research.
Thanks so much!
Dave LaRonde
Re: Best Codec For Exporting 16 or 32-bpc With An Alpha Channel on Windows
on Oct 28, 2015 at 9:42:38 pm
Get your mitts on QT Pro for Win -- version 7.x. You'll have access to PNG & JPEG 2000.
There aren't any codecs with 16-bit color. Not even ProRes 4444.
Dave LaRonde
Promotion Producer
Ryan Paterson
on Oct 28, 2015 at 9:59:21 pm
Really? So what's the output option in AE for "Trillions Of Colors"? I always assumed that was 16-bit?
And yes I am currently using the QuickTime PNG codec so I guess I'll stick with that
Dave LaRonde
on Oct 28, 2015 at 10:15:41 pm
I'm not sure if the Trillions of colors deal shows up in PNG. It's good in image sequences.
Like ProRes 422, PNG is a 10-bit codec. And it's lossless to boot.
Dave LaRonde
Promotion Producer
Ryan Paterson
on Oct 28, 2015 at 10:17:17 pm
Awesome, thanks. But just out of curiosity- in general what does the "trillions of colors" option represent?
Dave LaRonde
on Oct 28, 2015 at 10:58:53 pm
I wish I could say. I've always wanted to use it myself. None of the codecs I use for delivery are capable of it.
Dave LaRonde
Promotion Producer
Walter Soyka
on Nov 2, 2015 at 2:03:30 pm
[Ryan Paterson] "But just out of curiosity- in general what does the "trillions of colors" option represent?"
"Trillions of colors" in this context means that the output module will pass a 16bpc RGBA image to the encoder. To output 10-bit ProRes or CineForm, for example, you'd need to render with Trillions of colors. Rendering with "millions of colors" would only provide 8-bit renders from the output module to the encoder.
Walter Soyka
Walter Soyka
on Nov 2, 2015 at 1:53:32 pm
[Ryan Paterson] "Hello, recently switched from a Mac to a PC and without the use of ProRes now I'm trying to find a suitable replacement for rendering high-quality footage. Can someone recommend a codec that fits the specs in the title please? It seems AVI & Animation only support 8bpc, and I'm just plain unfamiliar with anything else really. Any resources regarding this topic are also welcome, wouldn't mind doing a little research."
Creative Cloud includes support for CineForm, a cross-platform, high-quality mezzanine format comparable in quality and compression ratios to ProRes. CineForm supports 10-bit YUV and 12-bit RGBA.
Walter Soyka
