Grey outline Alpha Inverted Trackmatte
Bernhard Walzl
on Oct 28, 2015 at 8:17:30 pm
I need to create a black video with transparent text. So only the characters from the text are transparent so the underneath video can bleed through the letters.
For this I have an illustrator file with transparent background and white text.
I import this file into after effects. I use this file to Trackmatte option to cut through.
However, when I use a black background I can see a grey outline of the text.
It looks like the track matte uses only the 100% white to cut through, the grey outline of the text remains white.
here an example :
Whats wrong here? how can i make the r and e disappear and only the white c remains visible?
Dave LaRonde
Re: Grey outline Alpha Inverted Trackmatte
on Oct 28, 2015 at 8:21:06 pm
If you're using a Luma Matte, change it to an Alpha Matte.
Dave LaRonde
Promotion Producer
Bernhard Walzl
on Oct 28, 2015 at 8:22:25 pm
this is using the alpha inverted mask. all the other masks don't give me the result I am looking for.
Dave LaRonde
on Oct 28, 2015 at 9:43:47 pm
Well, what's it look like over a real background? You might be worried about nothing.
Dave LaRonde
Promotion Producer
Bernhard Walzl
on Oct 29, 2015 at 5:13:26 pm
well, that was the reason why i didn't see it at the beginning. i always had a light bachground which worked just fine. until yesterday when the background was dark and i clearly could see it :(
Cassius Marques
on Oct 29, 2015 at 5:36:35 pm
well you got yourself the answer, the letters' halo are caused by the grey pixels originated by the anti-aliasing. you can make it go away with a small simple choke effect or increasing your alpha contrast. (probably after you pre-compose your matte result).
