Problems of white lines around any objects
Mit Panchani
on Oct 28, 2015 at 4:06:19 am
I am having an problem as described in image -
Any object i draw in after effects , when i zoom in to align with other object there is 2px thick white line beyond actual boundary of shape.
This varies as i move the object in the composing area.
Is that normal or i need to do something to get rid of it?
I have selected no stroke - its 0 px.
occurs in all new projects too , i.e. its global for me.
screenshot - https://goo.gl/photos/jNSbu5SLbUGDPkdUA
John Cuevas
Re: Problems of white lines around any objects
on Oct 28, 2015 at 1:28:20 pm
What are your comp settings, aspect ratio, pixel aspect ratio. Also, can you post a screen shot of your timeline with any changes to the layer twirled open?
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Mit Panchani
on Oct 28, 2015 at 4:42:35 pm
1080 at 25fps
I havent turn stroke on. it's 0 pixels
Dave LaRonde
on Oct 28, 2015 at 4:40:18 pm
Sorry, your screen shot isn't showing up in the link. But I think you have a stroke applied to your shape. You should check.
Dave LaRonde
Promotion Producer
Mit Panchani
on Oct 28, 2015 at 4:43:15 pm
No strokes applied.
Kalle Kannisto
on Oct 29, 2015 at 7:15:43 pm
Please provide a screenshot like this no we can narrow down the possible problem:
Mit Panchani
on Oct 29, 2015 at 7:28:23 pm
Here is the second shot
Kalle Kannisto
on Oct 30, 2015 at 8:02:13 am
I don't see any problem there, only an antialiased soft edge from the shape not being aligned to pixel edges.
Mit Panchani
on Oct 30, 2015 at 8:09:57 am
So that's an absolute normal thing?
That changes the opacity as i change the position of the object.
When i move the object with arrow keys, there is one position when that line becomes solid and no more a hindrance.
Kalle Kannisto
on Oct 30, 2015 at 12:22:33 pm
Yes, that "in-between color" pixel is normal sub-pixel sampling. That is how most pixel-based imaging programs deal with edges that don't align perfectly to a specific pixel edge, they blend the values in an attempt to produce a smoother output. It is the same as you see in the outlines of the text, just on a vertical edge that is not aligned to a specific pixel.
Essentially you will have to make sure that the edges are mathematically exact to get rid of that effect.
A potentially useful resource for you:
http://chrissilich.com/blog/after-effects-expression-snapping-objects-to-wh...
You will still have to make the solids an even number of pixels wide and tall for this to work on every edge.
Mit Panchani
on Oct 30, 2015 at 2:11:47 pm
Thanks for the guide. Understood what you conveyed, cleared my doubts.
