Importing a photoshop video timeline animation into after effects
Olubukola Laditan
on Oct 27, 2015 at 12:55:12 am
Hello. I have a photoshop document with a video timeline. I imported the file into after effects and everything seems fine except that the animation is about 60 times longer in after effects than in photoshop. for example a frame with a duration of 20 frames in photoshop will be 1200 frames in after effects. Both documents are set to the same frame rate and resolution. How do I fix this? Thanks.
Roland R. Kahlenberg
Re: Importing a photoshop video timeline animation into after effects
on Oct 27, 2015 at 3:00:36 am
Take a look at your AE's Preferences. Specifically Preferences>Import. Take a look at Still Footage and Sequence Footage fps settings.
You may want to look at http://www.schoolofmotion.com/photoshop-animation-series-part-1/
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
