How to reset beginning time for a clip
David McMillen
on Oct 22, 2015 at 7:23:07 pm
After Effects CS6. Many times, all I am doing is rendering a portion of a file and saving to a new file. However, when I close the file I extracted from (I do not save as a project) and load the file I rendered to, the starting current time is not 0:00:00:00 but is the beginning frame of the extract from the original file.
A simple example would be:
I open a 5 minute File01.flv in AE, drag it to create a composition, set the Beginning at 0:02:00:00 and eNd at 0:3:00:00, a one minute clip and render to Clip01.mp4. I close without saving as a project. I then open Clip01.mp4 and drag to create a composition. I am expecting the starting time to be 0:00:00:00 but it is 0:02:00:00. How do I "fix" this? I don't see anything in render options or other options.
Thanks for the help - David
Dave LaRonde
Re: How to reset beginning time for a clip
on Oct 22, 2015 at 7:54:01 pm
There's no fix... well, no GOOD fix.
You'd have haul out a time code calculator to adjust the comp's beginning time time code so the desired part would start at zero. And that's a pain.
Now, there are applications that let you alter time code on clips. I've never used one. I just know they exist.
Dave LaRonde
Promotion Producer
David McMillen
on Oct 22, 2015 at 8:13:28 pm
Thanks Dave. Sounds like that's the intended behavior, so AE must encode into the file. Any idea why it does that?
Dave LaRonde
on Oct 22, 2015 at 10:50:21 pm
No clue why. Frankly, I've never even looked into it. It's a non-issue for me.
Dave LaRonde
Promotion Producer
