Card dance
stig olsen
Card dance
on Oct 22, 2015 at 3:59:36 pm
Is it possible to do a card dance effects between two objects? Or pictures in this case.
Stig
Dave LaRonde
Re: Card dance
on Oct 22, 2015 at 4:33:23 pm
You can't make one instance of Card Dance work with two layers. You'd have to apply it to a nested comp containing two layers.
What are you trying to accomplish by doing this? There may be a better way.
Dave LaRonde
Promotion Producer
stig olsen
Re: Card dance
on Oct 22, 2015 at 4:43:38 pm
Hi Dave,
I want the hat to break up into fractured pieces and the fractured pieces to form the second hat. In other words, I want to use the card dance as a transition between two objects (hats in this case)
Stig
Kevin Camp
Re: Card dance
on Oct 22, 2015 at 7:17:51 pm
card wipe might be better suited for a transition...
it's been a while since i've used card wipe, but i remember it had 'jitter' settings that could be manipulated to sort of explode out an image. i think you could time that up with the transition property and make them re-form to the other image.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Frank Feijen
Re: Card dance
on Oct 22, 2015 at 7:16:16 pm
Can't you achieve the same effect with card wipe?
It lets you transition frome 1 source to another, with cards...
