Translating masks from low to high resolution art.
Jason Hata
on Oct 22, 2015 at 4:43:08 am
Hi there, I would say I'm pretty seasoned with After Effects, but I'm sure I missed some basics here and there.
So I'm working on a personal project just for kicks, where I grabbed some artwork off the web that I liked and wanted to add settle animation for a 10 second loop. I spent quite a bit of time masking out pieces and started animating already.
I later discovered that there was a much larger sized version of that artwork. A difference between the low quailty 1024x1501 and the larger art at 3475x5093. Is there a way to preserve all the masking work that I've done or would I basically need to rework all of the masks that I created to fit the larger art? Once a mask is created, is there a way to just scale the mask itself?
Thanks very much in advance!
Kalle Kannisto
Re: Translating masks from low to high resolution art.
on Oct 22, 2015 at 6:22:28 am
Are the mask paths animated? If not, you can simply select them all and scale (free transform).
If they are animated, you could probably use the low-res layer as a track matte for the high res layer.
