Rotate an Element 3D particle array around another Element layer
Jesse Wekerle
on Oct 20, 2015 at 5:57:03 pm
I am trying to rotate an Element 3D particle array around another Element layer. Normally I would achieve this effect with CC Cylinder, but I believe this is not possible with an Element layer, as I cannot choose to render just the inside or outside of the array to place outside part behind the object I am rotating around. HELP!
Cassius Marques
Re: Rotate an Element 3D particle array around another Element layer
on Oct 20, 2015 at 6:10:01 pm
You should check this page or the video tutorial covering the same subject.
