Lines
stig olsen
Lines
on Oct 19, 2015 at 9:12:02 am
I'm looking for a good way to make the "lines" that you see in this video at 00:22 - http://www.toxic.no/work/edgefolio.toxic
Best, Stig
stig olsen
Re: Lines
on Oct 19, 2015 at 9:22:18 am
I realize that I could sketch up some lines with the pen tool and use stroke to fill them, but then I want to make them "dance", or move together.
Best, Stig
Kalle Kannisto
Re: Lines
on Oct 19, 2015 at 9:38:55 am
For no-plug-in approach, see this:
Then there are plug-ins such as Plexus that make this much less a manual task.
Tudor "Ted" Jelescu
Re: Lines
on Oct 19, 2015 at 9:57:46 am
http://www.motionboutique.com/connect-layers/
Tudor "Ted" Jelescu
Senior VFX Artist
stig olsen
Re: Lines
on Oct 19, 2015 at 10:49:19 am
Thank you!
I've downloaded linescreator but I think I would try "connect layers" as well Ted. Is it a way to make the lines "move" between the dots, like stroking?
Best, Stig
stig olsen
Re: Lines
on Oct 19, 2015 at 11:36:59 am
And how is it possible to create that 3D effect`where the dots are moving in 3d?
John Cuevas
Re: Lines
on Oct 19, 2015 at 1:17:57 pm
If you are using the tutorial above with the beam effect, you can set the "length" to 100%, then animate the "Time" from 0 to 50% to have the line animate on.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
