Transform Problem
Sam Randa
Transform Problem
on Oct 17, 2015 at 10:28:14 pm
Hello!
I have had this problem for a while now, and I have found ways to avoid it, but this one I can't avoid.
When I put Transform of to a photo and I have cc tiler in an adjustment layer, the rotation of the photo "spreads out" the CC tiler.
Here is a photo explaining the problem: https://gyazo.com/1939979fa8a55841cfabd170963378d2
Please help!
Kalle Kannisto
Re: Transform Problem
on Oct 18, 2015 at 7:28:27 am
A better approach would be to use Motion Tile followed by the Transform effect on your adjustment layer. Tile first, transform second. Don't rotate the original image directly but with the Transfrom effect after tiling it. And Motion Tile is better for tiling as it expands the output area.
Sam Randa
on Oct 18, 2015 at 2:35:04 pm
Thank you for that, but I have solved that problem by using S_WarpTransform instead of transform.
