need to select keyframes on hundreds of layers
Riccardo Sinti
on Oct 7, 2015 at 8:53:05 pm
i have hundreds of layers and want to select keys on all of them but don't want to drag and scroll across all those layers.
1. is there a way to select every layer's keys on a certain property?
or ever just the property itself?
2. is there a script that will select every visible or hidden key across all selected layers either at time or within work area?
thanks!
Ashish Gupta
Re: need to select keyframes on hundreds of layers
on Oct 8, 2015 at 8:37:18 am
You can simply press U in the comp to reveal all the keyframes on all layers, then press Ctrl+Alt+A to select all the visible keyframes.
Alternatively, Press the shortcut for the property, say P for position to reveal position for all keyframes, then use the same shortcut to select all visible keyframes.
Ashish Gupta
Motiongraphics artist and 3d generalist
aashi.29nov@gmail.com
