how to make sticky effect on solid/shape layer?
Bas v Breugel
on Oct 2, 2015 at 7:43:53 pm
Is it possible to make this effect (without frame by frame mask path) ?
http://codepen.io/lbebber/pen/OPjxZL
Tudor "Ted" Jelescu
Re: how to make sticky effect on solid/shape layer?
on Oct 3, 2015 at 7:35:33 am
You can use shapes for the dots, animate them and pre-compose and then apply Refine Hard Matte to get the sticky effect. The only issue with this is that you will get a feathered edge, so once you get the animation that you need done, duplicate the layers several times to get a sharper edge.
Tudor "Ted" Jelescu
Senior VFX Artist
Kalle Kannisto
on Oct 4, 2015 at 8:58:14 pm
Gaussian blur plus threshold would also give a very similar result.
Ashish Gupta
on Oct 5, 2015 at 10:10:59 am
After blurring shape layers you can simply use a simple choker to correct the feathered edge.
Ashish Gupta
Motiongraphics artist and 3d generalist
aashi.29nov@gmail.com
