Mask and Adjustment layer
Vasco daNeva
on Sep 30, 2015 at 3:02:18 pm
I want to mask out an object from a clip. Because the object rotates (and I don’t know how to rotate the rather complex mask shape I created with the pen tool) I decided to apply the mask to an Adjustment layer (which I can rotate) and the result was good. But… the mask doesn’t mask. Shouldn’t it?
Daniel Waldron
Re: Mask and Adjustment layer
on Sep 30, 2015 at 4:05:36 pm
You can't mask out layers below with an adjustment layer. The mask will affect any effects you have on an adjustment layer, but it won't "remove" the areas in the layers below. Instead of putting your mask on an adjustment layer, put it on a solid and set your layer below to Alpha Matte Inverted.
Vasco daNeva
on Sep 30, 2015 at 5:42:20 pm
Thank you very much indeed.
Vasco
