Pre comp animation stops when keyframing in anotber comp
Rob Harris
on Sep 26, 2015 at 6:59:18 pm
im just starting out with AE and have created a flying bat with animated wings in a precomp. I have then brought this into a main composition, the loop works fine until I try to move the bat through the air with position keyframes - but during the animated position frames the animated wings stop and are just static and only begin animating again when the bat stops moving position....any ideas whats causing this, as I just want to move the bat through the air with wings animating all the time.
many thanks
Rob
Walter Soyka
Re: Pre comp animation stops when keyframing in anotber comp
on Sep 28, 2015 at 12:28:20 pm
That shouldn't happen, but you haven't shared very many details about your system or your project, so it's tough to diagnose.
Step 1: Try clearing your cache.
Ae CC/CC2014:
Edit > Purge > All Memory & Disk Cache
Ae CS6:
Preferences > Media & Disk Cache > Empty Disk Cache
Also, if you are running Ae CS6, make sure you've installed the updates. The persistent disk cache feature was new in CS6 and there were a good number of bug fixes in the CS6 point releases.
If this doesn't work, please come back with detailed system specs, Ae version, and maybe a screenshot or video capture showing your full UI and the problem you're having.
Walter Soyka
