After effect workstation for Raw, Your thoughts?
Dror Heller
on Sep 24, 2015 at 5:58:19 am
My computer is no longer strong enough for my Raw full hd footage.
Im trying to build a new pc, my main work is in after effects, the most important thing is that the software will be very responsive and fluid. (timeline straching, masking, previewing....)
The computer will be connected to 2 27 inch screens, 2560x1440 10 bit and full hd 8 bit.
What do you think about this system?
i7 5820K
Noctua hn-d15
msi x99s sli plus
Ripjaws 4 4x8ddr 2400
gigabyte gtx970 g1 gaming soc 4gb
I have 2 issues that im not sure about.
is the best way to use storage with after effects is to put 1 ssd for operating system and softwares, 1 ssd for source video files, 1 ssd for rendering and 1 ssd for cache disk?
is the gpu strong enough for the monitors?
Thanks a lot
Tudor "Ted" Jelescu
Re: After effect workstation for Raw, Your thoughts?
on Sep 24, 2015 at 8:31:38 am
Looks like a good system - one suggestion though, I would use 3 SSDs in Super RAID 2 ( http://event.msi.com/nb/faq/q12.html ) for video, rendering and cache, instead of having a separate one for each. Blazing fast on my machine - no issues with RAW HD files.
Tudor "Ted" Jelescu
Senior VFX Artist
Chris Wright
on Sep 24, 2015 at 2:16:47 pm
hey tudor check out the new samsung 950 pro. It outperforms SATA SSDs by over 4.5 times in sequential read and by over 2.5 times in sequential write, delivering the speeds of 2,500 MB/s and 1,500 MB/s respectively.
Tudor "Ted" Jelescu
on Oct 1, 2015 at 3:07:06 pm
Will look into it - thanks.
Tudor "Ted" Jelescu
Senior VFX Artist
Dror Heller
on Sep 24, 2015 at 4:05:34 pm
Thank you for the fast reply!!!
So you suggest to have 1 ssd for system and software and 3 ssd working in super raid 2 for the media, video rendering and cache?
reading media and rendering it to the same drive wont slow it down?
Do you think the gpu is good enough for the monitors?
Thank you so much
