After effects script composition duration
Ross Mac
on Sep 21, 2015 at 12:11:54 pm
Hi all,
I would like to create or use (if already available, though I cant find it) a script that changes multiple composition durations.
Basically I have created a project that checks a bunch of different things such as broadcast legal colours etc and also burns in titles etc...
I have one composition called "INPUT" that is used in all the other compositions. So whenever I change the input compositions layer all layers using input are updated throughout the project. Which is great but it would be better if when the input layer is changed to a file of a different duration all the comps would be changed as well and trimmed to match the duration of the file.
This way I can simply change that file and render out the various render comps without manually going in and changing the duration each time.
Anyone know of a script that does this or a way of getting after effects to do this would be greatly appreciated.
Cheers
Ross
Dave LaRonde
Re: After effects script composition duration
on Sep 21, 2015 at 5:28:00 pm
What exactly are you doing? Tagging spots, for example?
Dave LaRonde
Promotion Producer
Ross Mac
on Sep 22, 2015 at 9:32:32 am
Commercials playout/versioning with some qc.
