How to make a video like this....
Luis Garcia
on Sep 18, 2015 at 9:17:26 am
Hi! I am trying to do a video like this...
It is a selfhelp video, and I would like to know doing it for myself. The most important thing I would like to know is how to do the text so quickly, in a random mode.... The images I know how get the effect.
The text is a continuos flashing... I donĀ“t know if perhaps with a script I could do it....
some idea?
Thanks in advance
Roland R. Kahlenberg
Re: How to make a video like this....
on Sep 19, 2015 at 6:59:32 am
It looks more like a very fast scroll. You can do this with the Effect>Stylize>Motion Tile and the Expression -
loopOut("cycle").
You'll need TWO keyframes for the Tile Center property. Leave the x value at its default. For the first keyframe's y-value, set it to 0, for the second y-value, set it to the height of your composition. The two keyframes should be close together - about 4-7 frames apart.
Then, apply the aforementioned Expression to the Tile Center prop. Of course, enable Motion Blur for the layer and Comp. Adjust Motion Blur settings to taste.
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Luis Garcia
on Sep 21, 2015 at 8:40:18 am
A lot of Thanks... I will try it!
