Expression to check if Time Remapping on a given layer is enabled or not.
Nathan Churney
on Sep 16, 2015 at 7:43:16 pm
Howdy. I have a for loop that goes through a large number of layers and returns a result based on what the timeRemap value of that layer is. The problem comes when one of the layers within that set doesn't have timeRemap enabled, the expression gives an error and disables itself saying the layer doesn't have time remapping on and can't use the time remap property. I'm trying to write a little bit of code that checks out if a layer has timeRemapped enabled or not so it can skip the step of using the timeRemap property entirely on an un-remapped layer. So, a simplified version of my code currently looks like this:
for (var x=1, x <= 10, x++){
var y == y + thisComp.layer(x).timeRemap;//*this is the line of code that gives me an error when it encounters un-time-remapped layers*//
My "solution", provided someone can tell me code to check if layers are time remapped or not
if(//*here would be the bit of code checking if time remap is enabled for layer(x)*// == true){
var y == y + thisComp.layer(x).timeRemap;//*nestled in the if-then, it'll only perform this line if time remapping is enabled*//
}else{
//*empty statement, for layers without time remap enabled*//
Any ideas on the bit of code, or an alternate solution?
Walter Soyka
Re: Expression to check if Time Remapping on a given layer is enabled or not.
on Sep 16, 2015 at 8:56:53 pm
You can use try/catch [link] to look for a time-remapping value and recover if execution of that line fails.
See another example here:
https://forums.creativecow.net/readpost/2/1061942
Walter Soyka
Nathan Churney
on Sep 16, 2015 at 9:37:28 pm
Awesome! Got it working. Thanks!
