Camera Not Working With Particular
Sam Randa
on Sep 14, 2015 at 12:55:34 pm
Yes, i am a motion designer.
I have had this problem for about a day now, and I can't do what I do without it being fixed.
So, I have a camera in C4D that is the child of a circle spline.
I rendered it out normally, and then dragged the C4D file in AE
I extracted the camera out of the C4D file and now Particular is not reacting with the camera.
I know it is not a problem with Particular, because I changed the Particular layer to be a 3d layer, and that still did not solve the problem
By the way, the Particular I'm talking about is Red Giant's Trapcode Particular.
John Cuevas
Re: Camera Not Working With Particular
on Sep 14, 2015 at 1:15:21 pm
The particular layer should NOT be a 3D layer. Particular takes the 3D from an AE camera and uses it to project it's particles in a 3d within the plugin. Turning the layer into a 3D layer will create a flat layer that will not be 3D. Change this back to a normal layer and if you are still having issues, please upload a screen grab of your timeline.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Sam Randa
on Sep 14, 2015 at 1:31:04 pm
Here is a screen grab of what is happening (a gif)
https://gyazo.com/c9c15bf9901d4086c524804f85362ee0
The BG is not moving with the text.
Here is what it looks like in c4d
https://gyazo.com/0aab92a7be291179ef02b80b7e87824a
Thanks for your help!
John Cuevas
on Sep 14, 2015 at 4:47:56 pm
It looks like you didn't have an alpha tag when your rendered out your text. You should have a layer above your text image sequence and a luma matte. You can check to see if particular is working with your camera by turning off the text layer.
ThinkCK
Sam Randa
on Sep 23, 2015 at 6:59:24 pm
I did have an alpha tag (if you look very closely you will see orange smoke)
The camera just was not responding
Sam Randa
on Sep 14, 2015 at 2:22:05 pm
So I decided to scrap that project, since that was only about 20 mins of work (But a whole lot of rendering) and that was the only file that did not work.
