Saving a font style via the preset method is really baking my noodle :-(
David Honan
on Sep 10, 2015 at 10:59:07 am
Morning from 18 degrees C sunny York UK but windy as usual...
In After effects CC 2015 a have three text colours I need to use but right now because I cant work out how to save custom presets I am manually entering 3 different hrefs into the colour palette.
I know this is a dumb, slow way to do this and i know there are other methods to re use font styles you like but i want to have a go again ( I have posted previously on this) on learning how to save a font style as a preset for easy re use.
Below illustrates my pain again:
9253_aeremembercolurs.jpg.zip
Thanks in advance,
David
Walter Soyka
Re: Saving a font style via the preset method is really baking my noodle :-(
on Sep 10, 2015 at 12:05:12 pm
Ae is not awesome at this -- it would really benefit from Illustrator-style swatches. See this thread for a couple ideas:
https://forums.creativecow.net/thread/2/1048374
With regards to my homebrewed palette system, I put a Fill effect on text and color it with that.
Walter Soyka
David Honan
on Sep 11, 2015 at 11:33:54 am
Thanks Walt for taking time out to offer a better approach :-)
Dave LaRonde
on Sep 10, 2015 at 4:14:09 pm
If you need three precise text colors more than anything else in a single comp -- all considerations of typeface, kerning, nested comps, etc. aside -- just make three text layers in a big, fat, wide typeface in that color.
Turn off the eyeball icons to make them invisible, and rename the layers to make the colors meaningful to you: "Dull Red", "Shocking Pink", "Baby Poop Brown".... you get the idea. Move them to the bottom of the comp's timeline so they're out of the way.
When you need a color, pull the layer to the top, make it visisble and use the eyedropper to retrieve the color.
Dave LaRonde
Promotion Producer
Walter Soyka
on Sep 10, 2015 at 4:32:21 pm
Good point, Dave. I often do a variation of this -- I'll build a "Palette" comp with big solids of each color, then pop it on top of my comp, make it a guide layer so it doesn't render, scale it down into the corner of my working comp, and sample it with the eyedropper whenever I need.
Walter Soyka
Dave LaRonde
on Sep 10, 2015 at 6:14:54 pm
Well, that's a lot more efficient than my idea. Thanks.
Dave LaRonde
Promotion Producer
David Honan
on Sep 11, 2015 at 11:33:24 am
Thanks Dave :-)
