How to edit motion path on shape transform for a position
Doni Donovan
on Sep 10, 2015 at 7:13:28 am
This is my first thread.
For every trick i am always found on this forum but now i cant found a solution to make a curve for a movement position.
i have a shape layer and there are some ellipse on it.
when i create 2 keyframes on Transform: Ellipse 1 - Position (this is not the layer transform), i cant see the line for edit the curve of the movement.
the only way is i just try to copy a path to the position property so the movement is going curved now but i still cant see the curved line like on layer transform position.
Tim Bentley
Re: How to edit motion path on shape transform for a position
on Sep 10, 2015 at 9:46:37 pm
As far as I know you can't visualise the motion path of individual shapes, but you could create a null, link the shape's x and y position to the null's position and then animate the null.
http://timbentley.info
