Restricting Size of Conformed Media Cache
Manish Gurnaney
on Sep 7, 2015 at 11:35:20 am
Hi All,
I am using Adobe After effects 12.x version, I am facing some problem with Conformed Media Cache.
As I am using After effects a lot, Conformed Media Cache is occupying a huge memory, and in the span of week it occupies around 60Gb in the main drive.
My question here is, Is there any way by which we can restrict the Conformed Media cache? Once it reach the threshold it should clear all the cache.
Regards,
Manish R Gurnaney
Dave LaRonde
Re: stricting Size of Conformed Media Cache
on Sep 7, 2015 at 3:21:47 pm
Just purge your caches. It takes 2 minutes.
Dave LaRonde
Promotion Producer
Manish Gurnaney
on Sep 7, 2015 at 4:32:40 pm
I Agree with you, but I am running the script and rendering using Extend Script, which is run again and again, So If the space is full it will block the execution and rendering will be stopped.
Walter Soyka
Re: Restricting Size of Conformed Media Cache
on Sep 8, 2015 at 9:28:06 pm
Don't confuse the Conformed Media Cache with Ae's persistent disk cache.
See here for a description of the Conformed Media Cache and what it does:
https://helpx.adobe.com/after-effects/using/memory-storage1.html#media_cach...
Note that it's different than the disk cache we usually talk about here:
https://helpx.adobe.com/after-effects/using/memory-storage1.html#id_37671
Walter Soyka
