DPX sequence conform in After Effects
Daniel Lorenzo
on Sep 6, 2015 at 2:28:10 pm
Hi everybody
I have got an xml imported into After Effects with quicktime reference files that need to be replaced by dpx sequences with 2" handles. When I replace the files the dpx start at the beginning of its corresponding Quicktime file. I´ve checked the DPX and they do have its correct timecode embedded, matching the quicktime files. It could be done then manually, but is there a way in After Effects to replace the quicktime files with the dpx with timecode sync?
Thanks in advance
